Dinero
So I need to replace the radiator due to heavy rust, over heating. It seems that the radiator and shroud come out together as one unit. So I keep reading that the fan needs to be removed first. So I removed the 4 bolts that hold the fan and the fan dropped down. But there is no room to between the shroud and the air pump and alternator to remove pull the fan out of the way. So do I also have to remove the air pump and alternator to make enough room to pull out the fan? Am I missing something or doing something wrong. Please advise. Thank You.
