1988 Fiero GT 5 Spd.
magrams6
I can only shift into 1 and 2. The shifter will not move to the right. Any suggestions
the shift linkage is internal to the transmission.
does it shift into the other gears with the engine off?
have you checked the transmission fluid level?
how many miles on the car?
did you have any warning signs, noise, difficult to shift, etc.?
It doesn't shift into when the engine is off. Transmission fluid level full and clean. 145000 miles
It is driven very often. No warning signs, noise or difficult shifting. It had been sitting for about 6 weeks.
It doesn't shift when the engine is off. Transmission fluid level full and clean. 145000 miles.
It isn't driven very often. It sits in the garage a lot . No warning signs noise or difficult shifting until now.
You need a shop familiar with the gretag transmission
The select cable is bad more than likely. It controls side to side as where the shift cable is back and fourth. I have owned 3 over the years.
