E
ElGrande
Just purchased a 1988 Firebird Formula (350 TPI), everything stock.
Tranny waits to shift into 2nd in low RPMs, lurching hard into gear. If you run a little hard off the line, it shifts into gear fine. Had the tranny serviced today (tranny fluid and rear diff), made it a little better but not as it should be. Buddy of mine mentioned maybe it has a shift kit installed.
How can I tell? If there is one, is it easy (and advisable) to remove? I'm not very familiar with trannys.
