L
Lisa Marie
Water.? For one thing the blinker isn't working, it's not a fuse, or bulb. The person I am buying the car from "rigged" it so the back blinker works but you can't tell from the inside *accident waiting to happen* but the front blinker if you look closely it is vaguely blinking or straining to blink.
The other problem is the car acts as if it is going to over heat it doesn't get to the red line but close to it then it goes right back down. It has a slow leak somewhere, so he says but I couldn't find traces of water anywhere. ** Could this be a heater core? I do know the heater blows cold air only. I was thinking that maybe the radiator would or atleast should be replaced.
The blinker.. I have no clue unless it's something to due with broken wires maybe. I thought I would get some insight before taking it in to the shop. I'd hate to send it in for an easy fix.
Let me know what you think, Thanks.
Lisa
Lisa
