1990 Pontiac Sunbird LE Convertible, 2.0 TBI with overdrive transmission has issues with transmission verses engine rpm. Engine has been completly overhauled, throttle body rebuilt with nos oem parts, and all engine and throttle body sensors replaced with oem nos parts. Engne does not idle consistantly but runs fine above idle. My worst issue is how the engine reacts when I shift from park to drive, reverse, or directly through to neutral. Transmission is a 5 speed automatic with overdrive. Engine rpm goes from a 400 /450 at idle to just under 1000 when shifting. What am I missing ? I've changed out the speed control and all external sensors I could locate near or around the transmission. These new parts are also nos oem components. Engines auto shifts up and down very well through MPH increasing and decreasing. Thanks for any and all suggestions.
