Have both windows that the doorman pops out of it's plastic socket and the windows fall inside the door. I have bought both new at Autozone and replaced both ribbons and plastic window guide clips in the manual window regulator tracks and on the glass. I have cleaned all the factory goo out of the entire mechanism. Sprayed it down with dry lube and silicon. The windows are still very hard to roll up and down. Is there somewhere I can buy the whole mechanism new and/or the door frame window track channels? I suspect they are worn, bent, or damaged. I do not want to go to a salvage yard and expect to get something good, especially after they would have to drill out the rivets and pry the tracks out of the door. I am through with this effort. If it can't be fixed without spending a couple hundred dollars I'm parting it out, awful shame. This was a low miles 4 door granny car that was front end wrecked and I put it back together. Any help with this would be appreciated.
