I changed one head on my V6. The engine had 190,000 miles on it and I wasn't about to spend too much money on it. It had a blown head gasket because it overheated. It was not an aluminum engine. Basically all I did was replace the head gasket. I did lap the valves and cleaned the head up and the engine surface. I got a straight edge and checked for flatness of the head. Everything looked good and I used the same head bolts. All went well. You will have to find out the torque from a manual. I did buy an intake manifold gasket but I didn't really need to. It is best to because you don't want a vacuum leak. One of the plastic coolant fittings had a minuscule cracked that I didn’t catch until everything was back together, had to do a red-neck fix on this otherwise I would have had to take a lot of stuff off and replace it. But in the end all turned out good with minimum amount of money spent. (Even though I am rich in time, I am poor in money) Have fun.
