Hey all.
My Sunbird has been sitting for 10 years, no lie, waiting for a new cylinder head. It was in an insulated, not heated garage, and is in pretty good shape.
Rewind a bit, when I parked it I had replaced the cylinder head gasket in February and it failed again come December, water in the oil, etc. The oil was drained the head removed and it sat. Eventually I had a machinist look at it and he discovered the crack between the valves.
Fast forward to present. Purchased new/reconditioned head, rockers, lifters, new belts, new tensioner (old one was busted!), PCV hose assy, reassemble.
Engine is not firing properly, think my timing/ distributor is out of whack. Chiltons book is non descript on this engine. See here:
Fig 19 is this cars coil assembly where the plug wires go.
My first guess was match # to cylinder, no go, replaced plugs and tried wiring as per:
Fig 26 is no better. Fig 28 makes no sense to me at all.
One other thing is funny as well. The gas gauge is on high high.
Tried draining the tank with a siphon/pump and only got maybe 2 gallons out of it. The gas was cloudy and dark at first so figured this would fix it. Tried to refill from a 5 gallon jerry can and tank only acceptssame 2 gals of gas. Some kind of anti siphon in the line?
So probably bad gas and no idea on the plug wiring. Asking here first before I hit up the local mechanic for big help. And a big bill.
