C
cautioncones
noise? To start,im fairly good when it comes to cars. and recently i have been having a problem with my car squeaking,it will squeak when i go slow,like from a drive-thru order menu to the window,or just going slow in stop and go traffic,it dosent do it when im on the highway or such,the thing is,its not a constant squeak,it comes and goes,or it does it when for example say the M on the tire "michelin" is at a 12 oclock position,when it rotates back around a full 360,it will squeak,and it wil do it again after another 360 turn when im at slow speeds,i checked my front breaks and thoes are fine,i have rear drum breaks and i am not sure if it could be thoes,springs,coils,sway bar,becuase my trunck will also crack and squeak when i go over bumps,if anything can someone please tell me what to look for, weather or not its that part just so i can start eliminating things.thanks.
to the smarty pants that left a comment,im not doing 360's....the tire is....and i should have added this before,they guy who sold the car did nothing to it,i have already replaced all hoses,master cylinder,power steering pump/pully,transmission fluid,brake fluid,4 new tires,cleaned the fuel injectors,air filter,it was 145,xxx miles on it
all pullys have been checked,theres a new serpentine belt on it,it dosent sound like it has much to do with throttle,more of suspension,brakes,somthing of that sort
