1995 pontiac sunfire. need help if u know what your doing?
Larry
i have a 1995 pontiac sunfire 2.2 just put a new tranny in it it started up fine. now will not turn over at all. neutral safety switch is fine. all sensors and connected properly. fuel pump still makes noise. what could this be.?
Use a volt meter and check battery voltage...12 plus volts. Then check to make sure this voltage is going to the starter or starter relay. Remember...to check that you have a clean and tight battery ground wire as well. Voltage cables always need to be clean and tight on positive and the ground.
If it started once...it should start again...something didn't get put back tight or correctly. Good Luck Make sure to check fuses...and as I said, Cleanliness is next to Godliness when it comes to electrical and batteries.
