This link refers to your issue and I found the tech bulletin/recall, see if your
VIN falls in the range and if so check with a dealer.
http://www.obd-codes.com/p0410
Product Emission - Air Injection Reactor (A.I.R.) Pump System Failures #99083
99083 -- Air Injection Reactor (A.I.R.) Pump System Failures
1995, 1996, 1997 Chevrolet Camaro and Pontiac Firebird Model Vehicles
Equipped with 5.7L Engine (RPO LT1-
VIN Code P)
Condition
General Motors has decided to conduct a Voluntary Emission Campaign involving all 1995, 1996 and 1997 Chevrolet Camaro and Pontiac Firebird model vehicles equipped with 5.7L (RPO LT1-
VIN Code P) engines. The Air Injection Reactor (A.I.R.) pump emission control system on these vehicles may fail to operate and cause the Malfunction Indicator Lamp (MIL) to illuminate. This condition may be due to corrosion of a solenoid internal to the A.I.R. pump.
Correction
Dealers are to install a new A.I.R. pump assembly kit that is designed to protect the A.I.R. pump system from failing due to internal corrosion.
Vehicles Involved
Involved are all 1995, 1996 and 1997 Chevrolet Camaro and Pontiac Firebird model vehicles equipped with 5.7L (RPO LT1-
VIN Code P) engines and built within the following
VIN breakpoints:
Year Division Model Plant From Through
1995 Chevrolet Camaro Ste. Therese S2100001 S2229521
1995 Pontiac Firebird Ste. Therese S2200001 S2256723
1996 Chevrolet Camaro Ste. Therese T2100001 T2166869
1996 Pontiac Firebird Ste. Therese T2200001 T2232760
1997 Chevrolet Camaro Ste. Therese V2100002 V2160181
1997 Pontiac Firebird Ste. Therese V2200001 V2232666
