I have a 1997 Pontiac Sunfire, 2.4 L, manual transmission. (5 speed) I have been having some problems with it. The check engine light is on. I scanned for codes and I got P0132 (Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)) I have replaced BOTH O2 sensors. So I don't understand why this keeps showing up?
Right when you start the car the engine shakes pretty bad for about 10-15 seconds. Later in the day when you start it(once its warmed up) it doesnt shake as bad when you start it and it'll only last maybe 5 seconds with shaking. After that, it idles fine. But if you let it idle for a few minutes, and you try and press on the accelerator, it feels like it is about to die, so you have to give it alot of gas or it will die. It feels like it doesn't get enough gas.( If I am in a drive-thru I have to keep reving it up or it feels like it is going to die when I lightly press on the acclerator) It only does this when it idles for a few minutes and you try and accelerate. Sometimes the car hesitates when you press on the accelerator, and I have to press in the clutch and rev it up or the car won't go anywhere. I will have the gas pedal all the way to the floor and it just won't go anywhere. I hope I explained this pretty well..
I have replaced alot of parts thinking that they are the problem and they weren't. I've replaced the fuel pump, fuel filter, temp coolant sensor, spark plugs, coil pack, and cap.
Thanks to anyone who has any answers!!!!!!!
