1998 2.4L Valve Cover Gasket
ericv1984
Age
41
Lacey, WA
I have oil around my spark plug holes, seems to be more around cylinder 1 then there is around the other 3. I originally thought it was the valve cover gasket, but the 2.4L doesn't have a valve cover so I was thinking it's not called a valve cover gasket then. But, I was looking online and I saw listings for a valve cover gasket at O'reilly, AutoZone, and eBay. So is it a valve cover gasket or is it called something else? And would it be very hard to replace?
Is this the gasket set that I'd need? http://tinyurl.com/argwq5j
I just realized that there is two different sets. One is for the exhaust side and one is for the intake side, I think. For my problem, would I need both sets or just one?
EDIT: One set is 10.99 and the other is 15.99 at O'reilly, I just found a set that includes both at Rockauto.com for 11.82 plus shipping.
you are pulling the complete assembly as described in the instructions so you need all the gaskets/seals
