T
thebax2006
...way down.? It starts OK for several days and then won't start unless the gas pedal is depressed. When acting up the motor won't idle for up to 3 miles of driving. This has been happening on and off at random for 4 months. The fuel pressure is in specs. at idle and at 3000 rpm. No fuel leaks in pressure regulator vacuum port or hose. The throttle body is clean. No SES light or codes. I'm an Import Master Tech and this ones got me. Thanks for any clues.
It does not matter if the motor is cold or at operating temperature. It can be running fine, I turn the motor off and at start up a few minutes later it will either be OK or act up again. You never know when it will act up or run normal.
