So I acquired a 1998 sunfire from my inlaws that I use as a work car. It has a weird brake issue, when I'm applying the brake anywhere between 20-35ish miles an hour there is a weird clicking coming from just above the brake pedal. The brakes function properly the abs works as is should as well. I forgot to mention while this clinking is going on the lights are slightly dimming. It's definitely something electrical, I just didn't know what it is, possible relay? Any help would be appreciated. It only happens at low speeds 20-35 miles, any faster or slower than that and the clicking goes away.
