hearsedriver
- Jan 28, 2020
Hey guys. New member here with a newly acquired 1999 Firebird. A quick history of the car. 6 years ago, it quit running and was pushed into the owners garage where it sat until I purchased it. Absolutely beautiful car inside and out. It had a bad fuel pump which I replaced . After driving it a 100 miles or so, I found that the lower intake gasket was leaking coolant on top of the engine so, I replaced it also. The car starts and idles perfectly. The issue Im having is a surge while driving it until it warms up. Its a mild surge that is rhythmic at about once per second with maybe a 50 -100 rpm drop. After it warms up, it never surges. I have cleaned the injectors, replaced the fuel pressure regulator, replaced the spark plug wires, and cleaned the MAP and MAF sensors. I get no CEL or codes whatsoever. Im beginning to wonder if I am feeling a TCC lockup issue. The trans fluid looks good but I dont know when it was last serviced. Do you guys have any ideas on this? Thanks, Cliff
