1999grandam2.4l
- Jul 20, 2010
Ok, so when I'm driving at higher speeds and constant, like 55 or whatever, it doesn't overheat. When I am in town, stop and go, it rises up to half way in between 200 and 260. I turned on the car and it was around 215F or so I'd guess(1 or 3 little marks past the 200 mark) and the radiator fans weren't on. How do I check the relays, and where is the heat sensor at for the fans? Also, my ac and rear defrost quit working after I took apart my temperature control unit. The light for a/c comes on, but no cold air, and I think that the a/c compressor isn't kicking on. I took apart the temperature control because my fan wouldn't work on 1 or 2. So I'm just going to get a new one of those some time. If you could help with any of these problems it would be greatly appreciated. Thanks.
