1999 montana
jiml100
how do you get to the 3 back spark plugs on these vans ?
overhead dic unit does not come on anymore, checked fuse it is okay any suggestions ?
About the rear plugs ,do a search here on the forum and you will find a couple of members that changed them. From what I remember you take off 1 side of the dog bone(motor mount on the top front of the engine might be 2 not sure) then take a ratchet strap and pull the engine forward a few inches and that will give you room to reach down and change them. Wouldn't you like to have 5 minutes in a room with the engineer that designed this or better yet have them change them !! Also the second part of your question the dic ? Are you referring to the overhead dvd player ? If so I guess you have to find out if its the player or the screen that is bad once you find out look to the junk yards for a replacement part . Try this link for parts.
http://www.car-part.com/
Good luck and keep us posted , also pics are nice if your going to change plugs we all can use some hints and tricks .
