I've got a problem with a 1999 pontiac grad am v6 SE.
When turning the key to the start position, the engine will turn over once and that's it, then all you hear is the starter spinning.
every once and a while i'll be able to get the car started, very seldom though.
i have disabled passlock with the 2.2k ohm resistor method.
battery is brand new, no codes, can hear fuel pump turn on every time i turn it to "on" postion, but fuel in the rail seems weak.
confused.
any ideas on where to start?
Crankshaft Position Sensor?
confused.
