B
bushyviper
i bought a 1999 pontiac grand am from a tow yard, i went to go get it serviced and found out it had a major antifreeze leak and the people said its probably the water pump so i took it to a mechanic and he looked at it and said water pump and thermostat and another mechanic put it up on a lift and said it could possibly be a cracked head or block but the only thing it does is leak coolant badly the car has 134k miles on it and it keeps oil like i said only problem with it is the coolant leak
