caseyosullivan
- Sep 9, 2012
Hello. Ok, i just bought a 1999 Sunfire that won't turn off. Even while in Park, the ignition will not turn to the off, locked, position. I thought it might be the ignition cylinder, but even with a new one installed the problem persists.
The ignition has been rigged so the key can come out, even when not off and locked, and in order to turn off the car's electrical systems I have to disconnect the battery. I thought at first the Neutral Safety Switch may be malfunctioning, but wouldn't that cause codes to come up in the computer? Also, I had a Chevy once with a bad neutral safety switch, and it had problems starting because the computer couldn't tell when the car was in park. The Sunfire has no problems starting.
I am looking for opinions on what the problem might be. Shift lock solenoid? Parking lock cable? I just don't know.
Any help would be greatly appreciated! Thank you!
