hi i have tires from a 1987 toyota camry will the fit my 1999 potiac sunfire . same size, bolt hole pattern but i dont know about the offset and centerhole. can someone help me please
What size tires and rims do you have on the 1999 Sunfire and what size to you have on the Camry? Do you have the tires and wheels from a V6 Camry?
Pontiac has many different versions of the 1999 Sunfire , is yours a 2 door 4 door SE or GT or convertible.
From what I see if you have 15 inch wheels for both sets and you have OE size tires for both sets the only obvious difference is the Camry has a slightly shorter tire.
The measurement that is not provided is the diameter of the hole in the center of the rim. if the Camry wheels are smaller they may not mount up to your Pontiac. but the wheel dimensions seem to be identical.
