2.8 to 3.1 mod...?
moemann
I had heard that it is possible to make the 2.8 a stroker by installing a 3.1 crank and connecting rods. I know the journals match up but are there any other mods I need to make. Do I need new pistons or will the 2.8 pistons have enough clearance after the longer stroke of the 3.1 crank.
wouldnt it be cheaper to buy a used 3.1 and throw in new bearings and rings?
The stroker kit comes with a new crank and pistons. Make sure you get the pistons for the iron heads. The aluminum heads have a smaller chamber so the pistons for those versions will lower your compression a lot.
The rods are the same between the engines.
FYI - The 3.1L is a 2.8L with a different crank and different pistons. The 3.4L has the 3.1L crank and larger diameter pistons due to a larger bore.
