Hi forum! I am a F150 forum member as well and have many step by step how to jobs posted that I created. So check them out if you need to!,
I am having the some issue. I can go into drive and reverse sometimes. Seems like If I start the car, hurry and move the car into my shop, then put it in reverse then drive then it wont move. So I tried and my theory is if I start the car and hurry and move it, it will move but after 5 minutes or less it will not move anymore unless I rev the motor a little it seems to wanna move but wont really. Every time I first start the car I can move it but it eventually wont move.
I am not your average joe. I have been a mechanic for 13 years just never took a trans apart or had the opportunity to. All my engine swaps or work needed has never been related to a transmission problem. I have had great luck with customers!
Any Ideas would be great and please dont tell me to change fluid or filter I have already. I also triple checked my connections after replacing the engine. Also No leaks.
Yes motor was changed due to customer having a rod knock. Engine runs great! No Codes!
I need to test drive this car and get it back to the customer asap someone please have a clue!
