My 2000 Montana has a fuel leak. There is a good stream of fuel dripping with the ignition on the run position. It looks to be leaking from a quick disconnect located between the engine and fuel filter, under the vehicle just before the fuel line starts going upward towards the engine. I'm wondering if a quick disconnect can be the cause of the leak, I've never had one go bad on me.
I would also like to add that the smell of fuel was present within the last few days. Previously my fuel gage wasn't working for a long time with an error code related to the the evap, I looked it up online and it said the wrong fuel refill cap was installed.
edit
Never mind. The fuel line is rusted to the point that it broke when I tried to remove the quick disconnect.
edit
