wiring
Okay, a week later or so the windows quit working again, so finally I last sunday I decided to find the wire that was fixed and see if something was loose or what. when I uncovered the wiring under the floor carpet right by the passenger front door I found a lot of wires some bigger than others and found the one that controled the two front windows, after moving wires around the windows started working again and connection that was fixed seemed to be ok, also found the broken wire that controled the two back panel windows. Also I discovered many other smaller wires that had either become rotten apart or diconnected, not sure what went where my son and I fixed the window wires and put electrical tape on all the other wires that were not hooked up until I find a simple way to figure out what go's where! So by big question to everyone is where can I find a wiring diagram for this pontiac montana that would be simple to understand and hopefully by color?
