thebirdistheword
- Nov 12, 2013
My 2000 Pontiac Firebird 3800 Series II v6 has began idling around 1400 rpm after being revved over 2000 rpm. It did start leaking antifreeze somewhere around the water pump, i filled it back up with 50/50 antifreeze it was only a quart low, and the egr valve has been sticking causing it to idle rough but i cleaned out and the problem somewhat cleared up. The egr issue was around a week ago so i don't know if that is causing the high idle or not. Any ideas why it might be idling high?
