Willburg1989
- Sep 2, 2016
I am in need of some detailed diagrams of all wiring on the 12v side to the bcm,ignition, gage cluster and fuse panel. Which include all voltage for the wires. It started off as a fuel gage only working half the time. Took my dash apart . Did a quick trace and found a little botched wiring (looks like someone has possibly wired in a car alarm module as well. The gas gage worked fine for two days. Then started acting up a lot worse. Finally ,the car itself will not turn over. Only thing comming to mind is a botched bcm after the horrible wiring job by the preciius owner. If someone can give wiring diagrams Id be greatful.
