stinky1990
- Jun 28, 2010
I own a 2000 sunfire and I'm getting a check engine light code P1870. The code is for transmission slipping in 4th gear. I only have I work at Autozone and talked to local mecha it was programed for a 4 speed transmission that's why it is throwing the code. Just curiou anyone knows anything else it could be. Also when I'm sitting at a red light, ill occasionally get this noise from my transmission. It almost sounds like a gear isn't in the right spot and its touching something spinning because once I start moving, it goes a away. Is this an easy cheap fix? Or do I need a new tranny
