greenbf1
I recently bought a 2000 Sunfire with the 2200 engine and 98k miles. I changed the coolant and then began to have coolant drip under the right side of the car. If I lay on the ground, I see coolant dripping from a threaded hole in the area behind and below the water pump, not the pump itself. It is a pretty steady drip. Any ideas what might be my problem? I suspect the pump, but would like any input.
