The front right caliper of my 2000 Pontiac Sunfire SE 2.2L is not gripping the rotor at all, the pads are a little worn but aren't bad, and rotor is barely 3 years old.
We have replaced the caliper twice so we are certain it isn't the caliper, all brakes have been bled, all other brakes work. We have installed a new booster and master cylinder.
Fluid is definitely going into the caliper as we can bleed it no problem. The brake pedal goes to the floor and that particular caliper's piston barely moves. Front left caliper works perfectly.
The ABS light is on, it's solid yellow, and has been on for around 4 or 5 years now.
Any ideas?
Any ideas?
