I'll start by saying I don't really know my way around a car but I understand how everything works and have the Haynes manual. My uncles is coming over to help work on it so I figured I would try to figure a little bit out so we're not poking and hoping. I checked the codes the other day with my uncles code scanner and this is what I got. (I should note that my main goal is to get through Delaware Inspection as my inspection just passed)
From what I have read I think the EBCM may be bad but has anyone had experience with this? One thing that was going on was, when driving, often after driving maybe less than a mile or during a turn, the ABS, check engine, and low trac would come on at the same time. Also no cruise control.
Possible Scenarios that I've read on the forums:
1. Bad EBCM
2. Faulty wire/connection(we'll check the connections first obviously)
3. Bad Left Front Wheel Sensor causing the cascade of codes
Are there any recommendations of where to start, ex. Relays, Voltage, etc.?
C1214
ABS Enable Relay Contact Circuit Open
– The EBCM commanded the relay on but no voltage is detected at the motor
- or solenoids
C1225
Left Front Excessive Wheel Speed Variation
C1257
Left Front ABS Motor Circuit Shorted To Ground
C1265
Rear ABS Motor Circuit Shorted To Ground
C1262
Right Front ABS Motor Circuit Shorted To Ground
C1278
Right Front Solenoid Circuit Open or Shorted To Ground
C1276
Left Front Solenoid Circuit Open or Shorted To Ground
C1273
Magnasteer (VES) Actuator Circuit Open or Shorted To Ground
– The EBCM has detected that the Magnasteer actuator control circuit is
- at ground
C1286
Brake Warning Lamp Activated By The EBCM
Note: C1214 and C1273 may be crucial to a diagnosis
This is unrelated but maybe you could explain this to me
P0741
TCC Stuck Off
– TCC commanded on and the ECM detected the TCC slip speed higher
- than limits
Probable Cause
1. TCC solenoid failure
2. Open or short circuit condition
3. Blocked passage in transmission
4. Check Transmission Range Switch for proper operation
1. Bad EBCM
C1214
- or solenoids
C1225
C1257
C1265
C1262
C1278
C1276
C1273
- at ground
C1286
P0741
TCC Stuck Off
- than limits
Probable Cause
