Snidely Whiplash
Replaced radiator, all hoses, temp sender,CAP,thermostat (195 degree) but the gauge still says runs HOT. Fans came on shortly after start up and the top hose was luke-warm. But a hand-held digital thermometer shows a high of 201 after warming up. Pressure tested cold and hot, no pressure lost, and no pressure added during the run cycle.
Since it acted up to begin with, according to my neighbor-owner (light and gauge on, she said steam but no actual over heat), what could be the problem? Does the computer need to be reset to eliminate this obvious error on the gauge, or is the gauge not right and causes other issues, like a safe-mode condition?
I have circulation and the pump appears to be OK.
Burping the radiator with a lever- active cap produces no air into the recirculation tank.
Could this be in need of bleeding??? could air pool near the sensor? That's my only thought right now.
I'm stumped.
