v6tov8camaro
- May 18, 2012
Located in NYC
2001 Chevy Camaro 3.8L v6 engine & 4l60e Transmission
$1700? Make a reasonable offer
The engine has 97k miles but I swapped a v8 engine into my car.
So EVERYTHING is there to drop into a car. TurnKey Package
Complete Engine
Transmission
Drive Shaft
Rear Differntial(10 Bolt non posi)
Engine & Transmission Harness
Fuel Pump (GM Replacement Unit 2 Years Old)
computers PCM & BCM
All suspension - Kmember,Shocks & Spindles & Upper, Lower Control Arms
Disk Brakes, Calipers, brake pads, rotors, ABS - Perfect for LT1 cars for Disk Brake conversion
I Can demo for serious buyers only.
Engine is still in the car and turns on and drives perfect.
Oils Changed relegiously (motor, trans & diff), Coolant flush every 2 years.
Car held perfect oil pressure, and normal operating temps No leaks.
Call or text 646-450-1490
Can have it delivered in reasonable distance or shipped at buyer's cost.
Complete Engine
Transmission
Drive Shaft
computers PCM & BCM
