Psyex
2001 Pontiac Sunfire
I have a problem with a sagging drivers side door, it has dropped about 2 inches. It looks to me as if it is not a bushing problem but an alignment problem.
I am an experienced mechanic but I am not above asking for advice as I do not work on this type of vehicle often. If any of you have a trick for getting to that inner forward bolt on the car body side. To me it looks like if I want to have a relatively easy time I have to pop the pin so I can fit a ratchet or wrench in to adjust the carbody side of the hinge. Does anyone have a tip on a tool that can do this without having to pop the pin.
Before some jackass says use the search, I have, and there is only one post on the subject from 2011 and it is not the same problem. Thank-you kindly.
