problems? went to new york and along the way had to pull over , it will not go in reverse or drive and checked the fluids and it was low no burning odor but need to know if the cause was the fluids or the tranny
Chances are if the fluid was low it has fried the transmission they can not be run with low fluid levels (the clutches will burn up) you are probably looking at a rebuild or a different transmission..
