Olds_71_442
- Mar 18, 2012
I've got a 2001 Sunfire and back in mid December I was getting ready to go home from work when the car started and then made a clacking sound then chugged a little bit before it finally died.
I got it towed home and worked at it a little bit. I changed the coil packs, because the fire was hot to two cylinders and light for the other two. Still didn't work. I checked the fuel filter and it was plugged....but again, it didn't work. So today, I changed the fuel pump. The other one was weak, but still ran. I put in a used one that makes a lot more pressure than the previous one and yet the car still won't start.
When I put the battery back in today, it ran for about a second, then died and I got nothing after that. Sometimes it'll chug like it's going to start, but then it doesn't. I checked all the plugs and they have fire and supposedly I'm getting gas. I even tried pouring gas into the plug holes and still nothing.
I have no idea what else it could be? If you have fire and gas, the thing should start, right?
I should also add that the gas gauge goes wonky sometimes. It'll go from empty to full and then back down to normal. Plus, all the lights are on in the dash when I first attempt to start the car. But, I still hear the fuel pump running so I know it's not the Security Alarm.
