bradashton
- Nov 23, 2015
4 Cylinder engine. Every morning it has started just fine and some days it will even in the afternoon and night. But sometimes the starter will just crank and I have to remove the fuel pump relay under the hood, start it and let it die then replace the relay and it will start fine 9\10 times. The 1\10 times I have to replace the relay in the 2 seconds it runs and then it'll run fine.
I tried replacing the FP relay with the AC and there was no change. Also I tried cycling the key into the on position for 5-10 seconds a few times and that didn't work as well. The oil pressure light will sometimes blink and the temperature gauge will move a little but it's always running at the correct temperatures as far as I can tell and the oil level looked fine. Was thinking of trying a thicker oil. Any suggestions on things to try would be great, thanks.
