2002 Aztek Brake Line Treasure Hunt - Guide Needed!
smayfield
Sylvania, OH
Hi... 2002 Aztek here, replacing the rear brake lines... Original plan was just follow the line to the ABS module and hook each line to the appropriate spot... the lines are a bit hard to follow up, but I noticed the ABS module has colored dots/arrows where all the lines go... clearly it's a map! But I can't seem to find any reference to which colors are which... I know the yellow and purple arrows pointing to the back two connections mean "rear brakes" because I have new lines on the fronts (from a recent mechanic visit) and I can see the other 2 lines go to the brake fluid reservoir. So all I really need to know is which is left/right or does it not make a difference? Anyone know the secret code?
Right rear yellow
Left rear purple
Left front red
Right front green
Does that make sense?
Perfect, thank you! I learned also that they are etched with letters on each port, but I can't see the back (yellow/purple) so this helps tremendously!
