2002 sunfire ingition stuck on start wont turn off urgent
Rayc
san antonio
I have a 2002 sunfire the cant move the key out of the on position . i got a new lock cylinder but cant install it because its wont slide into position .since i cant turn the key back. And cant install ignition switch either since it wont move from the on position. Steering is not locked.
i already tried all of the solutions.
The old cylinder is out . cant instert the new cylinder barrell inside wont move into position
The cylinder is out. Cant get the new one
In the housing . it is stuck in the on position.
so you cannt turn the switch with a screwdriver in order to insert the new cylinder or is something else preventing inserting the new cylinder?
how did you remove the old cylinder?
Cant turn the housing with a screwdriver
Its stuck in the start position . it wont allow the new cylinder to pop in place.
I removed the old cylinder by pressing the button
the start position or the run position.
if the run position the cylinder should just slide in
