K
knotty
I am having a problem with starting when the vehicle is hot. The vehicle will start every time when it is cold, even when on short stops now and then. Once you drive it for a while,( a longer ride), then shut it off, then you try to start the vehicle it won't start. The engine turns over like it is going to start, but it just won't start. Fuel pump is pushing 50lbs pressure when running, but after it's hot it sounds like it is either not getting spark , or no fuel. We've had several computers hooked to the vehicle, but they all come up showing that everything is ok. No service light has ever came on at any time. I have no clue to what is going on.
