2004 2.4L V6 SE1 cranks, wont start
Sandybeech
My 2004 Grand Am 2.4L V6 cranks, but won't start. No security light. So, not a passlock problem. Can hear fuel pump turn on when key turned, cranks, turns over, just won't run. Battery tested at 12.7, so it's good. Car has fuel in it. Interesting thing is that the only lights on dash are SES, oil and battery. ? No fuel gauge reading and it's not showing the normal check of all systems by lighting up. What to check next?
Did you check all fuses and have you done a fuel pressure test and spark test?
