Hey all,
I have a 2004 Grandam with the 3.4. The right side motor mount has broken. This is an easy fix although two of the bolts have broken inside the front timing cover. I will have to remove it to get at them. The question is can the front cover come off without having to remove the oil pan? I know that the balancer and such will have to be removed and the bolts holding the cover. Can it just pull forward after this?
Thanks
R
Thanks
R
