I have a 2004 3.4. Wondering what all trasmission fit this? Since it a General Motors wondering if a Impala will fit or a sunfire? Thank you in advance for your info.
If you have a SE model the malibu and alero with the same engine should work for the
4T45E transmission. You have to compare them carefully especially the splines on the shafts and the mounting. If you are getting the trani from a junkyard they should have an interchange book.
