2005 Pontiac Grand AM- Hardly no heat is coming out of the floor vents or the...
Jockster
On my 2005 Pontiac Grand AM, hardly no heat is coming out of the floor vents or the the defrost on the sides (where the front side doors are.) Anybody know whats going on and how I can fix it?
Thanks!! :D
If you set the right side dial to face, do you get hot air? If you do then there is a problem with your blend door actuator. If you dont, have you checked your cooling system fluid level when the engine is completely cold?
My heat comes out hot but hardly no air pushes through the floor vents or the defrost (located near the doors).
Your blend door actuator has to be checked.
