woodworker
- Oct 27, 2014
experiencing something quite strange !
van started fine one day . next day wont even turn over ! no click no nothing ..
new battery , turn ignition and radio will come on all lights will come on . dash cluster as in "dummie lights " dont light up !! friend tried hooking up his computer and it wont connect . all fuses check ok but no power to abs fuse pcm/pass key cluster or pcm crank . checked all fuses under hood all check out of with test light . as for relay switches i dont know how to test . but there is 3 that are all the same so i switched them all 3 times hoping it might tell me maybe 1 of 3 was the problem . but no so lucky .. used screwdriver to jump starter and starter turns engine over but does not start ...
mechanic said my ignition switch was broke . so i purchased new one and installed it and everything is the same .. still no start no click . and none of my dash cluster battery light engine l8ght etc light up .. any suggestions appreciated ..
