2005 sunfire missing still
viper94bite
2005 sunfire idling rough and loss of power. replaced coil pack, plugs and ignition module. ran good for a day or so and started doing the same thing again. started as a misfire on #3 cylinder.
did you do a computer code check?
original code was p0303 after coil pack and ignition control replaced it says p0302. compression checks at 150ish for all cylinders.
code P0302 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
