2005 wiring diagram
larrys
my 05 sunfire starts and quits right after starting sometimes. a quick leave the key on will reset it and it runs normal again. thought it was the theft system bypassed that no luck. now thinking it might be a ground issue and i need a diagram to trace the grounds out and hopefully find a loose one.
wow 109 people looked at my post but no answers. well my mechanic tracked it back the the body control module, guess what he was wrong the car has the same issue as before back to the garage. im thinking of having him look at the ignition switch could it be momentarily not giving power to one of the modules?
If you turn the key to on position and hear the fuel pump engage and then stop before engaging the starter as opposed to starting the car right away, will it still stall immediately?
