2006 Montana tranny hard shifting
CFR
Hello everyone
I have 2006 montana sv6 ... when i am driving some times its shifting very hard then i turn it off and restart after 2 minutes then everything is normal ...no light, no transmission code, no slipping but why this happens? any body can help pls.
Thanks
To start with, when is the last time you changed the transmission fluid and filter? If it has been done recently you can try a transmission additive, Lucas makes one. If that doesnt resolve it then your shift solenoids may be causing the issue.
Just changed the oil the other day, thanks for the response.
The oil or the transmission fluid and FILTER?
Hello everyone
Thanks
Hi CFR,
I'm sorry to see you're having some concerns with your Montana shifting strangely. If you consider having your dealer take a look, we'd be glad to help. If you have any other questions or concerns, we're only a PM away.
Terrell
GM Customer Care
Any idea what it would cost to change the shift solenoids?
