Having intermittent lights/messages stating ABS system, Traction Control and Stability Control systems. Have put a scanner on it and it shows RF wheel speed sensor/wheel bearing issues. I have replaced both LH & RH wheel bearings in the last couple years. Lost the rubber seal on RH and used electrical tape to take place of seal. Found new seals at junk yard, installed, light went off for a bit , but came back on. What can I use to clean out the connectors?
Codes displayed:
C0131
C0040
C0041
C0043
C0253
I unplug the connector, plug back together, light goes off. Hook up scanner clean bill, all sensors read exactly the same on the scanner's data.
Need some direction here please!!
Thanks,
Derek
Codes displayed:
C0131
C0040
C0041
C0043
C0253
Thanks,
Derek
